Tire Changing Parts Missing (minor help needed)
This may be easier to look into someone else's trunk.
On the left eye hook & the lug wrench the next object over is...?????
(NOT the screwdriver/crescent wrench/Pin thing)
Rik
Rik
Phillips screwdriver, blank stud to screw in when removing wheel, U-shaped clip to remove wheel-nut covers, small hook to remove center cap on six-spoke wheels.
Is this what you need to know?
remove wheel-nut covers, small hook to remove center cap on six-spoke wheel-
-Rik
-Rik
In a 180:
Tow hook, 10mm wrench, blank stud for changing tires, round hook thing for "hub cap", Screw driver with philips/common driver, plastic bag for flat (I am missing this item). You will also have a jack, lug wrench and emergency triangle. I think that is everything.
