Tt 180 roadster transmission compatibility
Where to begin? 1 mo. Ago I bought an Audi tt that was in excellent condition or so I thought first thing I did was ordered bilstien pss9 ordered all new polyurethane bushings for front and rear suspension, new ball joints, rear h&r adjustable sway bar, all new shocks and strut mounts. I also chiped it using apr stage 1, upgaded to ecs air intake manifold power gasket, and installed an injen cold air intake. I installed all new lightweight pullies, new water pump, new timing belt and tensioner, new serpentine belt and tensioner. In addition I installed a stainless manifold, spyder led tail lights.... Now for the bad and ugly... While working on the front suspension I noticed the passengers side axle flange had a minor leak.. No problem I thought but boy was I wrong!!!
When I separated the axle from the flange I noticed the flange was full of gasket maker... I was pissed when I saw this, I took all the gunk out to access the bolt. the bolt is not the original so got even more pissed. I start to take the bolt out and I notice the bolt was cross threaded all of a sudden it just starts to spin but I can feel its grinding on something after fighting for several hours I decided to cut the bolt out and i got the flange out. After inquiring with different transmission shop the say the transmission is pretty much gone and I need to do a complete rebuild, which I don't believe the car was shifting perfect before all this. Then I had the bright idea to just do a transmission swap.... So when I do research on this I find the transmission code needs to be egz and I confirmed with the Audi dealer using the vin... Well what is on the car is not an Audi transmission, the code is egx and Audi dose not have this code so obviously it's a vw transmission now the question is what transmissions are compatible with Audi tt trany? I have found several transmissions that say they are compatible with egx. And I have found some that are even 6 speed that are compatible with egx but I weary of buying something that won't work and get stuck with a large paper weight ... Need help please advise on possible solutions.
If egx is compatible with egz, And (X) is compatible with egx, is (X) compatible with egz?
Audi TT 2000 Audi TT project car. $1500
mk1auditt
03-31-2019 11:44 AM
