TT Coupe window closing problem
Any advice or help?
The following incident happened occasionally for my TT:when closing the door(not slaming or pushing hard) the opposite side window automatically dropped down by itself by more than an inch. I needed to turn on the ignition to reset the situation before I can close the window with the window switch. However, I cannot reproduced the incident while at the dealer. They have changed the window controller module but it still happened occasionally.
Thanks.
Thanks.
Look for a section on resetting the window control. Happens to me every couple of months. Reset the window by pulling up on the window lever after its already closed and holding it in place. It's the same as resetting the windows to automatically lower with one push or not.
emergency at work. It was raining and luckily I got a spot outside our main building. I get out of the car lock the door and run into the building. Go upstairs only to realize that I left my pager in the car, go downstairs in the car and Ta-da the whole passenger side of the car is wet. Yep you guessed it, the window came down by itself.
arbrx
RS4 (B7 Platform) Discussion
06-16-2008 08:33 PM
Devius
10-19-2005 11:13 PM
