TT Trouble spots (longish)
First, this is not a bitching post. I want to get that out up front cause I'm about to list the things that have gone wrong with my TT - but not to complain but to find out what's common and what's not. Just got back from my first "real" service and I've got a heap of parts on order.
My dad has a brand new 225TTR and for any common failure that I go thru before him, the better I can make him feel if/when he suffers the same..
Ok, first off the DV. Yeah, duh. I have a Bailey and he knows about that and will get one if/when his cars starts having the symptoms.
Snapped camshaft - I hope I'm the only unlucky one.
Failed pass side window motor (on reorder so the pinch protection doesn't get triggered everytime you try to put the window up).
Heated seat switches on order, also temp sensors in case that's the real problem (hmm, I feel confident now!) so that the heated seats will heat on demand (vs whenever they feel like it).
Cluster needs replacing due to failed gas guage. They've got the part but I'm not having the car down 1/2 day for that then back in for the other parts.
Drivers side door panel was ordered due to defect in the pocket but it came w/o speaker cover and we learned today you can't reuse the original cover as it's melted (yes) into place on the cover.
Squeaky but other wise functioning rear wind deflector window.
Front plastic grill fell out and whole set was ordered (this is an old repair).
Squeeky pass seat when not occupied (or noise behind seat?)
Coupe owners have that privacy cover thing. Any other "common" things I should expect (sigh)?
I still really like the car and wouldn't give it up even with the above list. I got my gas tank filled for free today so they could prove the tank sensors were working - I'm trying to see the positive!
thanks
thanks
Squeaky pass. seat is because of metal and plastic rubbing together...
underneath. These are two pieces of the seat bottom. My favorite tech put the fuzzy side of velcro on the place where they meet, voila! no more squeak.
Wow..a lot of problems there Julie..not sure I'd have your patience. .. Had my 225TTR since June and
fingers crossed have not had one problem.. except maybe too many winding roads and not enough time..
I'm trying to make some lemonaid! :)
My warranty was extended by AoA when the camshaft went south. Still, I'm hoping it settles down.. else I'll have a good excuse for the TTS when it arrives!
A couple in common...
Rear windscreen rattles behind passenger seat from wind turbulence (only happens when top is up). The rear windscreen no longer goes up or down at ANY time (stuck up).
Rattle behind the passenger seat. I know it isn't the seat because it occurs when in use and when the seat is empty (and when it is tipped forward). Can't seem to find the cause of rattle.
My windows acted up at one time but haven't repeated.
