is TT worse than A6 in snow?
I have a new TT quattro (in Connecticut) with all-season tires and I've gotten a lot of advice that I should get snow tires for the winter. But I've driven an A6 quattro for the past 7 winters without snow tires and had no problems. If the roads are bad, I slow down. The thinking seems to be that the light-weight TT with wide tires will float on the snow. Can anyone comment? Does a TT really need snow tires when an A6 does not?
Please check. You cannot run summer tires in the cold and snow. Highly recommend a separate set of winter tires for the TT.
I live in the Chicago area so we get a bit of snow ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
Can't compare to my TTRQ 'cause it lives in the heated garage and just gets started and driven around the block during the winter (it's never been in snow or much rain in 5 yrs).
My TT definitely has all-season tires. Even says so on the window sticker. So I guess a follow-up question is - has anyone driven thru a New England winter on all-season tires in a TT? In case it matters, the TT is 225 hp, manual trans.
Having owned and driven an A4 and S4 in the snow, and family members' A6's, I've tried all of them. The TT isn't that much lighter than those, less than you might think anyway. I'm not sure if I like haldex vs. quattro for the snow yet, or if it makes much difference.
I think it depends more how much snow and ice you'll be driving in, cause that determines how extreme a snow tire you should get. Even the all seasons you got with your TT aren't as good as some all seasons in snow, they're more performance biased all seasons. Yes, you'll make it through some light snow in those, but you'll be safer in some real snow tires if you see quite a bit of snow. And even then, you're right to slow down and play it safe when it gets slippery. Remember, 4 x 0 = 2 x 0 with traction.
Burn up those silly no season tires you have, get snows for the winter (I love my Nokian RSi's, having tried lots of things), and get some real sport tires for next year....your TT will love you for it. I just posted yesterday, Kumho MX's only $109 each in 225/40/18's, and edgeracing.com has some good deals too for next summer.
Rich
Rich
