TTR unplagged wire...
<center><img src="http://www.seatclub.gr/gallery/albums/LEON20VT4/kalodio_007.jpg"></center><p>Hi to everyone!
A few days ago as i was cleaning the department behind the seat's (were the roof goes when is open) at the drivers side, i found an unplugged black wire (photo). I thought that it was the rear window's heating but i turned it on and it works fine.. So i don't know if this wire is unplugged from somewere or not.. Can anyone help??
rear window defroster in the hardtop. Normally it is tucked inside the bead on the edge of the top and is only removed when you install a hardtop. You can try and snake it back but just leave the insulation on it so it doesn't short anywhere we you use the convertible rear window defroster. There's one on each side although I think the other side has two connectors if I remember correctly.
RedBlackYellow
06-09-2001 07:32 PM
