TTSchwing, question for you...
I see you duplicated the AWE vent insert ring for the Boost gage mount. What diameter is the gage? Do you know of a similar gage (backlit with lighted needle) that would fit, and cost less than AWE wants ($140)?
I just took a Vent ring apart, and spec'd out the holder. It will fit a standard a 52m gauge (not 45mm like AWE), and retain some Cooling through the vent. I'll have this inexpensive ($18) solution available in a few weeks....
<img src="http://images7.fotki.com/v126/photos/7/7305/1500018/52mmVentGaugeHolder-vi.jpg">
It will easily mount in a disasembled vent ring and look just like the awe set-up depending on your choice of gauge..
<center><img src="http://www.omorimeter.com/images/45mm-AMCO-025-BZ-N_small.jpg"></center><p>
They make this one...(45mm)<ul><li><a href="http://www.omorimeter.com/images/45_Boost.htm">http://www.omorimeter.com/images/45_Boost.htm</a</li></ul>
Hmmmm...Maybe a Modshack version..:-)<ul><li><a href="http://www.omorimeter.com/custom_gauges3.htm">Omori Custom program</a></li></ul>
52mm mechanical boost gauge with imperial units:
<img src="http://www.omorimeter.com/images/52mm-AMCO-125-BZ-P.jpg">
<a href="http://www.omorimeter.com/images/52_Boost.htm" target="_blank">More info</a>
