UK: Where is the comfort control module?
Hi,
I have a 2005 TT Quattro Roadster with a bad Comfort Control Module. Can someone please tell me where it’s located? Thanks.
![](https://cimg9.ibsrv.net/gimg/www.audiworld.com-vbulletin/1500x2000/ccm2_6a83fbc3debca9157f3fa3ffec74bb61c10a7ba4.jpg)
CCM access panel
![](https://cimg1.ibsrv.net/gimg/www.audiworld.com-vbulletin/640x480/rear_deflector_a27f6e1ccc8c5e83738ff7b2998d07905a4d793d.jpg)
It's under a panel on the parcel shelf behind the passenger seat (US). It is bolted to a bulkhead against the trunk. You can see mine in the first panel covered by a gallon zip-lock bag that I covered it with to help waterproof it in case of leaks since it is located right below the bottom corner of the window where the glass starts to separate from the fabric.
I accessed it from the the top through the parcel shelf behind the passenger seat. I don't know if you can get at it from the trunk side, but it is on the opposite side of a bulkhead from the trunk, so you'd have to be a contortionist to do it. Normally the parcel shelf has limited access too due to the roof needing to be up and the roll hoop(s) being in the way. I was in process of installing a new roof when I took the photos, so the access was as easy as it gets.
Georgeko (06-27-2024)
bspurloc
Q7 MK 1 Discussion
08-11-2021 11:51 PM
araines77517@gmail.com
06-26-2019 03:28 PM
Stoney
10
11-20-2001 11:50 AM
