Ultimate TC-650 (2x130) front components for the TT. What's your opinion?
<center><img src="http://pictureposter.audiworld.com/54811/tc650.jpg"></center><p>
My sound system is stock (it's the concert I think). I intend on adding an amp and a sub sometime in the future, and maybe rear speakers. Are these speakers loud enough to give me some more power at the moment and to be able to get connected to the amp later (something like 4x100 or bigger)? Or should I go with something better than them? When I raise the volume over 20, it the sound is not clear anymore right now. Is it going to get better with these speakers? I removed them from my x-Golf. Thanks for every opinion...
P.S. Other numbers required :
Mid Woofer 6.5"/165mm
Dome Tweeter 1"/25mm
Impedance 4 Ohms
Power RMS 65 Watts
Power MAX 130 Watts
Frequency response 58Hz - 25Khz
Sensitivity 92 dB
Mid-woofer Mounting Depth 2.52"/64mm
Crossover Network 2-Way, 12dB<ul><li><a href="http://www.ultimate-sound.com/products/components/compti.html">http://www.ultimate-sound.com/products/components/compti.html</a</li></ul>
Impedance 4 Ohms
Power RMS 65 Watts
Power MAX 130 Watts
Sensitivity 92 dB
a crap? I mean if I upgrade all this stuff, I don't think it will be that bad or underpowered, right? If I have it connected on a powerful amp, I will solve the problem (note: I will add the required Blaupunkt adaptor to make the connections), am I correct?
DeadLy
11
12-09-2006 04:22 PM
TTear
03-24-2004 01:35 PM
craig '93 90Q
12
09-11-2003 09:56 PM
jayel
9
12-08-2001 11:05 PM
