Update from AOA. They say that my warranty is no longer valid.
They made it clear that my warranty will not cover mechanical issues. If my door handle falls off, it will be a case by case. She even included the DV in the mix of things of why they will not touch the car. Dave since you have a VAG tool and everyone else that has one, please use it to remove the fault codes before taking your TT into service. Evidentlty just swapping ECUs or resetting them will not do the trick to find out what your engine has been doing.
<ul><li><a href="http://www.channel2000.com/kcbs2/bogey/survey.html">http://www.channel2000.com/kcbs2/bogey/survey.html</a</li></ul>
While it sounds really bad, the point is that they will figure out whether the item being covered is in any way related to the mods and will cover it if it isn't. This seems reasonable, though their language is a lot scarier than it needs to be...
