Update on dianostic charge for bad Maf. Stealer said I was charged because I had two codes only Maf-
was warrantied. The second was for secondary air flow. They found a slow leak in the Combi-valve diaphram. So they refused to rebate the charge.
The diagnostic revealed the bad maf... the maf is a warranty item.
Did you approve the repair to the Kombi Valve? It's usually a busted vac hose that causes a code. The maf probably caused a check engine light.
It's likely that the Kombi valve leak might have caused a code, but not triggered a cel. If that's the case, they shouldn't be charging you simply because they saw the fault code when they scanned the car.
pattersom
08-04-2006 09:10 AM
aviattor.3
11
05-25-2006 10:29 PM
TT-Hombre
13
02-01-2005 04:31 AM
SlowestS4Here
10
11-06-2002 04:54 AM
