Update on Window Issue from yesterday...
#18
Sounds like not enough power is going into the motor. I think your motor and regulator are fine...
Get a multimeter. Hook it up to the 2 motor wires. Open/Close the window and see if the juice had dropped significantly from 12V or 14V (engine off or on) during opening. If so, it could be a switch or relay. Most likely the switch.
On the other hand, if you don't see a substantial drop in the voltage - maybe less than a volt, and the motor gets very warm, you know it's consuming all available current to fight a bind. Then it's the regulator or a window alignment
rkarsk
TT (Mk2) Discussion
01-22-2021 02:57 AM
