Upgraded Diverter Valve- Benefits?
I have read so many posts on getting a new DV- whether it be a Forge, strat or otherwise, but I'm not completely sure I understand the true performance benefit of upgrading from a stock one if it is not malfunctioning.
I do have the APR 93 program in case you want to tailor comments.
Thanks for the advice in advance.
also, with the newer units, they're adjustable, which really is nice.
further, they can be easily removed and cleaned, meaning that they'll stay all sorts of wonderful forever, if properly maintained.
the adjustment is essentially the same as the 'washer mod' on other dv's as it changes the spring pressure. you can do a search on this to generate much better information than i can provide. good luck.
what the differences (benefits) are with an adjustable vs. non adjustable (Hyperboost adjustable)
Also what about diaphram DVs (DVR from Forge) vs. Piston (007 from Forge & Hyperboost).
I am slowly learning about these, but more info and help is very appreciated. help
audiTTracer03
19
07-30-2003 03:22 AM
juttin
09-01-2002 11:21 AM
adjustable, advantage, advantages, benefit, benefits, bigger, diverter, dv, forum, performance, s4, upgrade, upgraded, valve, vd
