When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
2203 Audi TT quattro 1.8T 225hp
I've broken a check valve under the intake manifold circled in the attached picture. This is attached under the intake manifold to a triangular plate with part number 061155751AA PUMP in the Audi Parts manual. The part is not available in the U.S. and lists for $286. I only need the circled check valve. Is it safe to replace it with any generic vacuum check valve. Does anyone have any experience with the check valves? How specific are these vacuum check valves in the system? Thanks for the help. Part # 06A133751AA Pump
