very loud shaking in ac line ?
I posted once before i tore int this a little bit. it is not the tensioner. with the A/C or defrost on. the smaller a/c tube that exits the firewall shakes and couses a very loud rumble. the location is right where you would put a gauge on it. i checked the low pressure side with one of those cheap refill kits which read, low, correct, or high, and the pressure seems to be correct. there is a newer compressor on the car. i just purchased the car a few weeks ago and do not know when the compressor was replaced, but it looks to be only a couple of month old. this is the actuall hard ac line that causes this rumble if i hold it it does not change the sound. Any ideas?????
The expansion valve is a varialbe orifice type and should have been replaced when the compressor was. (You should have a Sanden SD7 variable displacement comp. ) If the sealed capilary which drives the diaphram in the exp. valve has leaked down , the diaphram may be cycling cousing a resonance ???
The valve block is easy to replace.(about $55 or so)
Need new O-Rings and a recharge.
My 2 bits....
My 2 bits....
passenger side firewall. The 2 ridgid A/C aluminium tubes attach to the front of the block using a single bolt and O-Ring face seals.
It's been a while.... sorry, I don't remember if the valve was a dealer part or sourced along with the compressor.
I would give em a call before you go to a stealership, they were great to deal with.<ul><li><a href="http://www.aircoparts.com/">A/C Parts Here</a></li></ul>
A8nightmare
06-12-2011 09:34 PM
konyo
06-28-2001 09:26 AM
