Visitor from the D2 A8 forum-help please
I am assisting a friend with a TT he jas just purchased and found the following faults.
does anyone have any thoughts please
2 Faults Found:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1602 - 35-10 - - - Intermittent
16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
P0011 - 35-10 - - - Intermittent
Readiness: 0000 0001
2 Faults Found:
i would say the Divertor valve has a tear or is broken. Depending on if it is aftermarket or OEM will determine your course of action..(repair or replace respectively)....
Based on the second errors, it is possible with a leak that the errors were caused by the DV....
Suggestion would be to repair the DV situation, clear the codes and see if the second set comes back.
Just my opinion
Just my opinion
cc46blu
04-03-2002 06:28 PM
