Vortex-er's addendum to Schwing DV mod
second post is a worthwhile read.<ul><li><a href="http://forums.vwvortex.com/zerothread?id=460893">http://forums.vwvortex.com/zerothread?id=460893</a</li></ul>
To me it would appear that if you are trying to tighten up the spring to hold boost (a tad bit longer) and the washers reduce the distance with which the spring can expand, what happens if the correct amount of boost that should be released doesn't get released? Turbo damage?
I maybe misunderstanding this mod, so I welcome clarification.
<center><img src="http://images.fotki.com/v7/photos/7/7305/130918/pressures-or.jpg"></center><p>
It just preloads the spring 5mm to hold boost a little longer and come on a little earlier. A boost gauge will show you this. Don't analyse this to death. As you can see from the cart, all the pressure/boost readings are in nice alignment with the ECU command pressure request. These results are on MY car, your results may vary but most who have tried it have been very pleased.
19885ktqcd in Wa. st
15
01-23-2004 12:15 PM
TTschwing
21
06-10-2002 02:00 PM
