Wanna buy a used 03 TT, have some concerns.
Hello everyone,
Here is the story, I want to buy a used Audi TT 03 convertible with around 27K miles.
The price seem to me a bit high compared to other TTs 13.5K, but apart from the broken LCD screen in the dashboard, I do not see other exterior problem.
I read a lot about the problems with the 1.8t engine 225hp:
What do you guys think?
URL:
https://www.audinatick.com/used/TRUUT28NX31011550.htm
- Coil missfire
- LCD screen
- Carbon buildup
- Oil pump at inside the oil pan (I think this is from the 2.0...)
URL:
I bought a 52000 mile 2001 Roadster last Feb. I did a timing belt and tensioner and water pump as soon as I got it home. The plastic water pump impeller did have cracks. I had to buy tires pretty soon too. They looked great, ( Michelins) but they were 10 years old and two of them separated after a couple thousand miles. Check the rear window seal to the roof carefully. Also make sure the door locks and trunk release work well with the key remotes.
It’s a good idea too to check the radiator fans. Both should run if the air conditioning is on. Good luck! We enjoy ours when the weather is nice.
JayZi
19
04-16-2007 04:56 PM
aTTicism
9
02-28-2006 05:39 PM
