water pump??? 2001 QC 180hp
I will be changing timing belt and water pump. I found Conti timing belt and rolls and now I need get to know which generic water pumps are the best and links where I can buy it. Thanks Marek
<center><img src="http://www.dieselgeek.com/images/DCP_4502.JPG"></center><p>
<ul><li><a href="http://www.dieselgeek.com/Detail.bok?no=278">http://www.dieselgeek.com/Detail.bok?no=278</a</li></ul>
Kit includes (click part number to see picture.):
06B 109 119A Timing Belt, Continental same exact part as OE
06B 109 243D Timing Belt Tensioner, same exact part as OE
06B 109 477 T-Belt Damper w/included 06B 109 244 roller, same exact part as OE. (Has old part# 06B 109 479 stamped on it.)
<B>06A 121 011T Graf or Hepu Water Pump with Metal Impeller (shown with magnet) and Exclusive Dieselgeek.com Water Pump Removal Kit (details at bottom of this page)</B>
050 121 113C Stock 87 degree Behr German Thermostat with 059 121 119 o-ring seal. (Behr is OE manufacturer)
06A 121 121C Thermostat housing cover (plastic, replace every time you touch it!), same part as OE.
038 103 085C "Extra Coverage" DPH German Cam Seal X 2 (one for behind cam sensor, replace if leaking), better than OE
06A 260 849C Serpentine Accessory Belt, Continental, same exact part as OE
N 105 167 01 Always-Replace Small OE Motor Mount bolts x2 (torque: 30 lb. /ft. + ? turn)
N 102 096 03 Always-Replace Large OE Motor Mount bolts x2 (torque: 44 lb. /ft. + ? turn)
<b>Kit
<img src="http://images18.fotki.com/v328/photos/9/925706/3815304/Kit-vi.jpg">
Tool</b>
<img src="http://images14.fotki.com/v336/photos/9/925706/3815304/dgkit-vi.jpg">
Tool</b>
not to say anything bad about the system. I wouldn't have been able to get it out at all if it weren't for the screws. My WP was on there @#%#@ tight. This kit is the way to go imo.
royalsovereign
06-22-2006 07:48 PM
Suds
01-08-2004 05:10 AM
