What is the latest opinion on transmission fluid changes?
Old 02-25-2009, 04:19 PM
ErnesTT's Avatar
Default What is the latest opinion on transmission fluid changes?
My '01 TT is up around 80,000 miles and I was considering changing the manual transmission oil.
I called my local Audi dealer to get an estimate and they told me I should never change the transmission oil. They said it was a life time fluid and I would cause more problems by changing it.
I am sure I read other posts that recommended changing the fluid with Red Line 90.
So, who's right? Should I change it or leave it alone?
Old 02-25-2009, 04:25 PM
JohnLZ7W's Avatar
Default When it comes to long term maintenance the dealer is very rarely right
New fluid at 80k is about the right time, Redline MT90, Amsoil GL4 or even factory fill will work.
Old 02-25-2009, 05:00 PM
heinzboy57's Avatar
I changed to MT90 at ~110k miles. Felt a bit nicer. Do it.
Old 02-25-2009, 05:47 PM
DumpTTruck's Avatar
Default Never? Wow. I changed mine at 80K KM's. The synthetic makes it so much smoother
My oil coming out was pretty dark too.
Old 02-25-2009, 06:13 PM
Joe Smith's Avatar
Default lifetime = as long as warranty
The dealer does not care if they are not footing the bill.
Yes, it should be fine with no change. But yes, it will last longer and shift better with an oil change.
Old 02-25-2009, 07:19 PM
SparTTan's Avatar
Default Cause more problems by changing it? Your dealer is an idiot.
I just changed mine for the second time at 160,000 miles. Transmission felt the same before and after the change; I did it more for preventative maintenance. The drain plug has a magnet, which had collected a nice layer of metal shavings. I used Redline MT90. You can use any synthetic 75w-90, including the OEM fluid.
Old 02-25-2009, 10:36 PM
pattreek's Avatar
x2
Old 02-25-2009, 10:45 PM
VelveTTrevolvr's Avatar
I would change it, Redline works wonders for my tranny
Old 02-26-2009, 06:18 AM
typ44q's Avatar
Re: x3 I have been using Redline in all my cars for years and really do think it helps
Bariukas
23
12-17-2016 10:59 PM
KingA4
06-16-2004 02:31 PM
81Audi4K5+5
06-08-2003 02:28 AM
nklemens
Audi 100 / A6 (C4 Platform)
03-25-2002 12:53 PM
svu
03-08-1999 01:07 PM
Quick Reply: What is the latest opinion on transmission fluid changes?
