what size of turbo on TT225q???
#15
He has both, chipped is 1.0-1.1 bar, 14-16 psi, stock S4 is 0.8 bar or 11-12psi.
Don't forget twin turbos and a 2.7L V6.
There is no way with two small K03's two more cylinders and 0.9 more liter's it can have more lag. It is a much more powerful engine!
#16
What's different, the impeller, compressor or just the housing...?
'Cause if it's the housing then it's not a different turbo. Although the housing affects quite a bit....
A K04 is a K04, as far as I understand it. The housings can be different, however.
#17
Didn't think of it that way. I thought 2 turbo double the lag. :) I always thought the S4 was
running at 14psi. didn't think it was the same as the TT. Thanks for the info.
nikhil
15
12-07-2005 05:57 PM
