Whats the difference???
Does anyone know how the 1.8t motors vary between the 180hp TT and the 225hp TT?? What is done mechanically or is it just upped boost?. I'm just curious as to the modifications that would need to be done to make it a 225 from a 180.
different. the 180s are very easily modded and there is actually more available for them (APR Stage 3) than for the 225.
Not matter what engine code or HP.. And they are all Forged.
The rods in the ATC and AMU are the same.. which are also the same as the rods in the AWD, APH, ATW and AEB. Basically 00 golf, jetta, GTI, NB (and some early 01s), 98-00 A4 and passat. And also older 16V VWs.. They are stronger then the later longitudinal and AWP transverse rods but still far from great. Its been aroun 350+ whp that the later AWP rods seem to let go. While you can get over 400whp out of the earlier rods before failure.
CR is very questionable because using VW as an example they claim the AWW (late 01 only engine) is lower then the AWP and AWD (like an ATC) however the parts are 100% identical between the AWP and AWW.. Also people have done some testing and found that they are all lower then what they claim..
Cranks are the same on all the DBW transverse 1.8ts so you are good there.
The rods like I mentioned don't see to have problems till about 350whp.. That seems to be the magical breaking point on the later AWW/AWP rods. They also unfortunately look like pics of the 2.0T rods which is very unfortunate... Whether they are the same or not they are made with the some procedure which is really the downfall and they are just as skinny...
I"ve got some AWP rods laying around.. not early rods though, but I may take a part a 16V I have soon.. If I do I'll post up some pics along with some Pauter aftermarket rods you can really see the difference.
