what's a DV and
It's a vacuum activated valve that helps to keep the turbo spooled up during shifting. The OEM valve is made by Bosch and it's a piece of crap. It's based on a diaphram that seems to degenerate pretty rapidly. The aftermarket DV's are piston based and use high temperature materials like Delrin, Nylon and Aluminum. Don't mess around, upgrade your DV.
how fast does the oem crap out? i have only 1500 miles on my car. will replacing it void the warranty? any recommendations for specific brands?
thanks for the info
thanks for the info
...complain of the thing making honking sounds and making the car surgy after just a few miles. Go figure.
I would recommend the latest, all aluminum valve from Stratmosphere.
<img src="http://www.stratmosphere.com/forge_piston_top_threequarter_320b.jpg" />
<a href="http://www.stratmosphere.com/forge_valves.htm" target="_new">Forge DV from Stratmosphere</a>
Mine went at about 6000 miles. Car would make a fffft-fffft-fffft-fffft sound when you got off the gas and the check engine light came on. They replaced the dv and everything was back to normal.
<center><img src="http://pictureposter.audiworld.com/1319/aaabbb23645t.jpg"></center><p>The DV valve is the shinny aluminum part in the back with the small vacuum hose attached on top.
