Whats the general opinion on boxster brakes on a TT? Anyone installed porsche brakes? Is it worth
You aren't gaining the heat dissapation of the larger rotor so I don't know what improvement it would be.
Also, the backspacing/fitting issue is because the caliper is wider and ends up hitting on the backside of the wheel face so it's not a matter of the rotor diameter.
brakes, but better stoping power is a big plus. Would porsche calipers mounted on stock rotor provide better stopping power? Or is the benifit so minute that its simply not worth the trouble?
disipation. So, if the porsche brakes were to apply MORE pressure, as they are a 4 piston caliper vs stock which is one..., the rotor would required to dissipate more heat, as there more surface area. So the potential to overcook the rotor would be much higher.
In most cases, a better rotor and pad, improves the rotor setup. Folks that do big brake kits, usually track a car, or it is for show. IMO
I figure about 500-600 for a boxster setup vs. about 150-200 for stock replacement. Just wondering if its worth the trouble.
the Boxster moves more out to the outer rim of the rotor. In this pic, Boxster pad on the bottom, TT on the top:
<img src="http://images12.fotki.com/v214/photos/4/435091/2588192/04Boxstervs_TTpads4-vi.jpg">
The biggest benefit is 4-piston (Porsche) vs. 1 piston (TT) so you get more even pressure distribution across the pad.
I got my kit cheap because someone who track's their car alot bought them and flipped them for StopTech's pretty soon thereafter. That tells me they are not the "best" option out there. He did say they never faded, but didn't provide the overall increase in stopping power he was looking for. They are an improvement over stock, though - I can tell that in my first day.
I wouldn't do it. If I needed more braking power I would look into whether Audi S4 Brakes could fit on a TT, or I would inquire about braking kits from Achtuning or another vendor that are made specifically for the Audi TT. Probably cross-drilled rotors are in order too...
