what's the life expectancy of the OEM brake pads? my brakes are squeaking like mad!!
The dealer at the time (6-8 months and ~10K miles ago) suggested that the squeaking was caused by rust build-up on the rotors/pads and there's nothing they or I could do about it. Can it really be an indication of worn pads? I've had the feeling recently that the brakes don't "catch" quite as they used to, but at my last service (25K) the dealer said everything's normal.
Should I go out and get myself new pads? EBC green I guess would be the way to go?
Thanks,
-Krunch
Thanks,
-Krunch
I'm at over 25,000 miles, and my pads are still operating almost like when I bought the car. Sure, I notice a little bit of degredation, but they still stop the car perfectly fine..
...a constand screeching can be the wear sensors hitting thre rotors. As far as the EBC's go, probably not a bad idea especially if you don't like the OEM dust, however you'll have to get those rotors turned with that kind of mileage on them.
..they'll shave off the surface on the lathe to give you a fresh metal surface onto which you can bed new pads. If you don't have the tolerance left, they'll replace your rotors.
