What's the maximum difference in size you can have for front & rear tires?
225/35/19 f & 255/30/19 (0.7% difference,problem maybe not enough rubber on front) -> 0.9% & 0.2%, respectively, difference from stock
235/35/19 & 255/30/19 (1.8% difference, rear is .5 in less in diameter, means the rears drop another .5) -> 2.0% & 0.2%, respectively, difference from stock
235/35/19 & 255/35/19 (2.2% difference, rears are .5 in larger in diameter in the rear, much prefered as the rears will slightly be higher) -> 2.0% & 4.2%, respectively, difference from stock
The front and rear tires cannot be more than 3% difference from each other, correct? If I stay with the 235/35 front (which I am currently running), I'll have the same spedo reading I have now, but with a 255/35 rears, I'll have the off set look.
Or...go 245/35/19's all around
1titSantorin
38
03-05-2009 10:00 AM
BIGDROCH
10-23-2004 11:27 AM
