whats the trick to the fuel filter clamps?
I used a needle nose plyers to get them off, basically you have to push in from the top, and then pull off toward the front or rear.
Make sure you have a bucket or pan nearby as the fuel will come out, but not that much.
Some have broken their fuel lines using that approach. It took me a few minutes but I was able to get them off without any tools. If I were going to use pliers, I would use a small vice grip to squeeze the fitting, then wiggle it off by hand.
comming out when i tipped the fuel filter backwards , fuel draining out the inlet. it came out black with little black grains it looked terrible. i tipped it the correct way and it ran relative clean, i be it has never been changed in 90 k now i got my A/C issues, oil leak, and routain maintance don time for the mods. I thin modshack has the Boost ring in stock now also. Thanks<ul><li><a href="http://tHANKS">http://tHANKS</a</li></ul>
Jargen
04-23-2007 01:21 PM
BlownHeadlight
07-31-2004 06:47 AM
ShoppingKartRacer
Audi 100 / A6 (C4 Platform)
09-07-2003 05:49 PM
The Devil
11-24-2002 01:47 AM
