Where to buy an exhaust gasket to join the rear to the front part of my Forge exhaust?
<center><img src="http://www.carcareonline.com/graphics/wurth_exhassy_11373.jpeg"></center><p><ul><li><a href="http://www.carcareonline.com/wurth_exhassy_11373.html">http://www.carcareonline.com/wurth_exhassy_11373.html</a</li></ul>
...for those that are not dead square:
http://www.percyshp.com/sealgas.html
or you can cut with an xacto knife out of a small sheet 12Ga. Lead after you template the flange on paper....<ul><li><a href="http://www.permatex.com/products/prodidx.asp?automotive=yes&f_call=get_item& ;item_no=80696">http://www.permatex.com/products/prodidx.asp?automotive=yes&f_call=get_item& ;item_no=80696</a</li></ul>
work as well, don't really need much those flanges are pretty beefy, and square. There have been a lot of questions about that flange, Forge needs to send a gasket and bolts to eliminate confusion
In Puerto Rico there's no Napa to buy the annealed copper sheet :-(
and then using an oxy/acetylene torch light torch cover the copper with the soot created from the flame, The lean out to a nice flame with oxy, slowely heat copper until the soot burns off @ that point it is annealed.
Silicone (HI-Temp) WILL work as well, its a very good option.
