Where is the door switch?
Getting intermittent issues where the driver's side door switch is not contacting properly when the door is open. Where is the switch and is it something where the contacts can be cleaned? Or is this a part that needs to be replaced? Any Bently diagrams? Part number? Degree of difficulty for removal/replacement?
TIA
TIA
For the driver side. Interior light will not come on, window will not drop, etc.
The switch has to be at fault, but I cannot see anything in the door jamb as like on other cars, must be buried in the door hinge or door handle.
Hey Peter - yes it's inside there - dealer replaced mine under warranty, see link.
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1420094.phtml">https://forums.audiworld.com/tt/msgs/1420094.phtml</a</li></ul>
try resetting the window first....take a look here...
roll window down slightly,
roll window back up and hold switch up for a few seconds,
then let go,
and then press switch to go back up.
should work then.
then let go,
should work then.
calbear92
02-19-2006 10:28 AM
loraxfromhell
11-16-2004 10:54 AM
