Who has changed their Tranny fluid? What did you put in? Brand\weight?
Old 04-23-2002, 07:51 AM
Senior Member
?lueshirt's Avatar
Default Who has changed their Tranny fluid? What did you put in? Brand\weight?
What were the results?
I am speaking with Redline. Ever since I put in MT90 75w90, my first few shifts grind. The problem is exaggerated on cold mornings.
Thanks.
Old 04-23-2002, 08:19 AM
Lloyd of the Rings's Avatar
Redline Oils MT90
Old 04-23-2002, 08:23 AM
Senior Member
evan's Avatar
dealer is currently changing mine to the new OEM fluid... will report when I get the car back.
Old 04-23-2002, 08:32 AM
CMH
Senior Member
CMH's Avatar
Redline in my A4.
Old 04-23-2002, 08:43 AM
Member
BigTT's Avatar
Default Redline MT90...
complete opposite of your results... had grinding/balky shifting before adding the Redline.... very smooth and conistent shifts afterwards.
Old 04-23-2002, 08:46 AM
Junior Member
ConeKiller's Avatar
Default Here is what i went with on my S4...
Front diff/trany(same oil) Redline lightweight shockproof oil
Rear Diff: Redline 75w-90NS
Thoughts
Cars shifting is much much smoother especially when cold. Rear end is way more grippy. Overall i would recommend these oils to anyone as the difference is noticeable.
Old 04-23-2002, 09:01 AM
Senior Member
?lueshirt's Avatar
Default Shockproof looks interesting....
<ul><li><a href="http://www.redlineoil.com/redlineoil/spgoti.htm">http://www.redlineoil.com/redlineoil/spgoti.htm</a</li></ul>
Old 04-23-2002, 09:09 AM
GoKart3's Avatar
Default Hmmm.... Looks like we'd use the "Heavy Shockproof" for durability. Are you>
thinking of trying this stuff out instead of the MT90??.
Old 04-23-2002, 09:15 AM
Senior Member
?lueshirt's Avatar
Default Well it would match out viscosity requirments, but
might be interested in the Lightweight since it seems in between MT90 and MTL. I think a little lower in viscosity might help in the cold startups.
I have to do something, my tranny feels terrible!!!
Redline suggested draining one quart of the MT90 and putting in one quart I of the MTL.
Old 04-23-2002, 09:48 AM
GoKart3's Avatar
Default I just noticed this part of Redlines info, and wondered if the lightweight>
and superlight might not protect the tranny.
"if further improvements in efficiency are desired, and durability is not a major concern, LightWeight and SuperLight ShockProof can be used."
Do you think the "Heavy Shockproof" would be too gooey? You might want to talk to the tech guy at Redline. I've spoken to him quite a few times... very knowledgeable, willing to help, etc... Can't for the life of me remember his name.... argh.
Quick Reply: Who has changed their Tranny fluid? What did you put in? Brand\weight?
