Whoops! Anyone happen to have a spare one of these? Broke it replacing vacuum lines today. Updated.
<center><img src="http://pictureposter.audiworld.com/77906/photo_11.jpg"></center><p>
Though am sure most of you know, this comes from beneath the "harness connector," passenger side.
Could be the "secondary air injection solenoid valve (it is 12V, so may be it).
I think the P/N is:
026 906 283 H
32/99 99T222
7.21610.00 12V
Broke the nipple (pointing to it w/green pen).
Thanks. If none have it, then it'll have to be ordered.
I think the P/N is:
026 906 283 H
32/99 99T222
7.21610.00 12V
Looked at pg 97-21 of Bentley. Though it has two screws holding it on (upside down on my car),
it doesn't exactly match. And, it's on the opposite side of where the picture depicts it in the Bentley.
I did the same thing... and temporarily repaired it
you can epoxy the broken piece of nipple back on
stick a drill bit or someting similar inside it while the adhesive cures so the internal passage isn't blocked by hardened adhesive
did this a couple of years ago... and it's still going!
World impex...had the "M/N" wrong...it's an H
Uh, more than I want to spend. Will look to what Russ did.
Thanks gents.<ul><li><a href="http://www.worldimpex.com/search_by_partno.html?searchmode=partno&partno =026+906+283+H&x=0&y=0">WI</a></li></ul>
Dayam! $12.34 at this site. Out of stock, but hey, may just get a new one anyway (and keep repaired
one as a spare).<ul><li><a href="http://www.partsquick.com/SearchResults.asp?w=026+906+283+H+&s.x=0&s .y=0">Talk about cheap!</a></li></ul>
I've had good luck with these guys ->
for OEM parts (although not all forum folks report the same)
you might give them a try<ul><li><a href="http://www.genuinevwaudiparts.com/partlocator/index.cfm?siteid=214407">genuineVWAudiparts.com</a></li></ul>
