Wierd suspension clunk solved... nothing more than a loose sway bar link
I have changed tires, used to adjust valves on my Karmann Ghia, I maintain my own and friends' bicycles...
Do you think my experience is a good match for the sway bar task sir?
(LOL! Sorry for the interviewee style; I am currently looking for a job
The tire shop listened to my sway bar with a stethoscope-like device and said the noise was more on the sway bar.
Which one is the sway bar?![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
Thanks...
Thanks...
Its not a sure fire fix but clunking is usually something loose. If you are out of warranty and want to avoid the hassle of bringing your car in, you can generally look for things that are loose and snug them up a bit. If you're under warranty, let someone else get dirty.
The sway bar has all of 4 bolts on it. One on each of the mounts/clips that holds it to either side of the cars sub frame and on on each end that attaches it to a long slender linkage.
You should be able to spot it pretty easy with the wheels off. Its a bar a bit smaller than the diameter of a quarter that goes across the car just behind the front wheels. It bends forward from under the car and will be attached to a slender vertical link 8 or so inches long on each side in the wheel wells.
The hardest part of snugging up these bolts is taking the front wheels off the car. If you can change a tire, you have more than ample skill to do this.
I actually checked the mounts but not the ends which is why I feel like a dumbass.
I wouldn't go crazy tightening the mounts unless you have a proper torque wrench and know the torque specs. Snug can get you by for a little while until you can get things torqued proper. Too tight will strip them.
Just don't get under there and try to tighten the hell out of them. They should be pretty snug but not super tight.
I have a tendancy to overtighten so sometimes I get a little over cautious.
the Quiet sTTorm...
10-23-2006 07:41 PM
Nepok
09-19-2005 09:59 PM
mobsTTa
11-13-2004 05:11 AM
cpayne
Audi Original "S" Cars
02-27-2003 07:30 AM
