Will 245/40/18 fit on lowered Rdstr. running 225's now LOOK like might be room.
Ok I'm kidding - otherwise a lot of my cars will need 100 width tires ![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
But seriously, 245/40 is a bit too tall as an 18. When going 70mph on the speedo, your road speed is almost 73mph.
You should try 245/35 but that limits your tire brand choices to something like Toyo and a few others - although you'll be happy with their performance. Another alternative is fit 255/35's which are about as big as 235/40's but are available by many manufacturers. You'll only be off by 1.5mph @ 70mph but that's not too bad.
And the suspension you are lowered with ... and your offset ... and how much you weight ... ;^)
I'm running 235/40-18 without any probs.
Lowered about 1.5". Rubs on the inside without spacers. Rubs with the spacers on the rear wheel well when I push it hard. I was going to raise my suspension soon. Probably about 1/2". You will likely rub your outer fender on compression with those spacers.
jujuC6
Audi allroad
15
04-29-2013 03:18 PM
beans912
20
04-16-2008 08:36 AM
V8_SPANKER
06-11-2002 08:08 AM
