Will Bolt-down coilpacks fit on a AWP engine?
Old 01-24-2008, 12:58 PM
  #11
GorTT's Avatar
Default that sounds WRONG. it sounds like the plugs aren't properly tightened >
and you are getting blow-back, forcing the CP's up. check that out.
Old 01-24-2008, 01:01 PM
  #12
TCU_TT's Avatar
Default Are you saying they are tightened too tight or not tight enough?
Why would it now just blow out coilpack 2 and not 1 and 3 like it did before?
Sorry if I'm annoying you with these questions I am just confused.
Old 01-24-2008, 01:21 PM
  #13
GorTT's Avatar
Default I'm saying if the CP's are blackened, it sounds like the plugs are possibly loose >
and check all the plugs - pull and re-install them, and properly torque. check carefully the top of each plug too - there's a fitting that can come loose or come completely off, exposing a length of fine threaded shaft - that also might be the problem.
Anyway, if it was Cyl. 1 and now it's #2 because you moved CP 1 to cylinder #2, then it sure does sound like you need to just bite the bullet and get an entire new set of them.
Old 01-24-2008, 01:33 PM
  #14
TCU_TT's Avatar
Default Thank you very much for your help and patiences GorTT
I really appreciate it. I think I might order some new CP's and then check the plugs while I have them out.
Old 01-24-2008, 01:35 PM
  #15
TCU_TT's Avatar
Default Have you bought parts from worldimpex before?
Are they a reliable company?
Old 01-24-2008, 01:45 PM
  #16
GorTT's Avatar
Default You' welcome! >
really not a problem at all - hope it helps you.
JosieAngel
9
05-19-2008 07:11 PM
audi4repair
11-04-2006 09:36 AM
EE:OutofBounds
10
07-11-2006 06:44 AM
caddidle
07-27-2004 10:16 AM
Quick Reply: Will Bolt-down coilpacks fit on a AWP engine?
