Worn Springs?
What is the best way to decide if your springs need replacing? I have some excess rear tire wear (like many) and have been told that it could be the springs because there is no rear camber adjustment on the Quattro. It's an 01 TT Quattro that hasn't been lowered. Any suggestions?
Springs eventually sag. Theoretically they will last as long as the car, but that is provided the rest of the suspension is in good shape. The shocks, in particular, are important.
If you crossed 80K miles and have the original suspension, then an overhaul is in order. My favorite setup is:
-Koni FSD + Eibach Pro kit
-16mm rear sway bar
-DEFCON 2
-Blue Haldex controller
-Fresh bushings, links, joints, etc..
-4 fully adjustable rear control arms to dial it in perfectly. CPT are the best.
-16mm rear sway bar
-DEFCON 2
MysteryMachineCoupe
15
02-07-2006 03:59 AM
cabriolet rear springs (8G0 511 115a) are cabriolet specific springs fronts are same as B4 except 93
wisconsin_quat
15
09-05-2003 05:31 AM
KiddJoey
04-23-2002 08:34 PM
