Yahooo....another check engine light!
Either I'm just this lucky or my car knows it is getting close to Christmass and wants to have some lights of it's own, but the CEL came on again this morning. I VAG Com'd it tonite and this is what I got...
VCDS Version: Release 805.1
Data version: 20081017
Monday,17,November,2008,20:06:18:59417
Chassis Type: 8N - Audi TT
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
VIN: TRUWT28N811033665
Address 01: Engine Labels: 06A-906-032-AMU.lbl
Part No: 8N0 906 018 K
Component: 1.8L R4/5VT G 0003
Coding: 06710
Shop #: WSC 01236
TRUWT28N811033665 AUZ5Z0A0250070
2 Faults Found:
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
Part No: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18446
Shop #: WSC 01236
3 Faults Found:
01314 - Engine Control Module
79-00 - Please Check Fault Codes
01423 - Lateral Acceleration Sensor (G200)
57-00 - Electric Circuit Failure
27-10 - Implausible Signal - Intermittent
Address 08: Auto HVAC Labels: None
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
No fault code found.
Address 15: Airbags Labels: None
Part No: 8N8 909 601
Component: Airbag Front+Seite 1008
Coding: 10103
Shop #: WSC 01236
Address 17: Instruments Labels:
Part No: 8N1 920 930 J
Component: KOMBI+WEGFAHRS. M73 D55
Coding: 07244
Shop #: WSC 06126
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 22: AWD Labels: None
Part No: 02D 900 999 X
Component: HALDEX LSC ECC 0011
Address 35: Centr. Locks Labels: 8Nx-962-267.lbl
Part No: 8N8 962 267 A
Component: Central Lock/Alarm D05
Coding: 15980
Shop #: WSC 06126
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8N8 951 177
Component: Innenraumueberw. D09
Coding: 00001
Shop #: WSC 00000
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00010
Shop #: WSC 01236
Address 56: Radio Labels: None
Part No: 8N0 035 186 A
Component: Radio D05
Coding: 00201
Shop #: WSC 00001
End ---------------------------------------------------------------------
Thoughts?
I was throwing codes (but no light) a few weeks ago for the MAF, N249, N75 and both o2 sensors. I replaced the MAF scanned again and my codes were gone. I dont know if this is related or not.
Coding: 06710
Shop #: WSC 01236
2 Faults Found:
P0102 - 35-00 - -
Coding: 18446
Shop #: WSC 01236
3 Faults Found:
Coding: 00140
Shop #: WSC 01236
Coding: 10103
Shop #: WSC 01236
Coding: 07244
Shop #: WSC 06126
No Faults Found
Coding: 15980
Shop #: WSC 06126
2 Faults Found:
35-00 - -
00955 - Key 1
Coding: 00001
Shop #: WSC 00000
Coding: 00010
Shop #: WSC 01236
Coding: 00201
Shop #: WSC 00001
Thoughts?
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1574799.phtml">https://forums.audiworld.com/tt/msgs/1574799.phtml</a</li></ul>
I have read it several times on here, but have never done it myself. I just bought the VAG COM. If I remeber right I check block 32?
