You CAN replace the 'Door Open' micro-switch in the door latch.
Old 05-08-2019, 03:54 AM
  #31
cjkeenan's Avatar
Hi folks, this one should work ok eh?
https://www.ebay.ca/itm/253041086680?ul_noapp=true
Thanks
C.
Old 08-28-2021, 04:22 PM
  #32
wvolvo's Avatar
I also have a 2002 TT 1.8 225HP. Also have a bad microswitch. The plunger is just cracked and half gone. I checked the Alibaba links above, but the item is no longer available. I found this one on ebay. It does not say it works with the 02 TT, but it looks very simliar. Does anyone know if this will work? https://www.ebay.com/itm/203099900832. By the way, when removing the latch assembly, I didn't loosen the lock on the door (or anything like that). I just unhooked the cable. I hope it goes back on OK.
Old 08-29-2021, 06:08 PM
  #33
wvolvo's Avatar
You can still get the switch here: https://shop.bmacvags.com/collection...le-microswitch
Old 08-30-2021, 06:07 AM
  #34
jjt1234's Avatar
Originally Posted by wvolvo
Nice!
Old 08-30-2021, 09:36 AM
  #35
ayoung63's Avatar
See my post on 08-12-2014. I used a switch with a little metal "flap". It's a better design where the plunger of the switch doesn't get stressed. You do have to get a little creative with the installation, though. I used plastic epoxy. 7 years later and it's still working!
New switch and old (broken) switch
Old 12-31-2021, 02:17 PM
  #36
TheTanman66's Avatar
Which of the three metal tabs did you attach the wires to? Did you cover the bottom with anything?
Old 01-03-2022, 12:31 PM
  #37
ayoung63's Avatar
Uhhhh, yeah, don’t remember which ones I used 7 years ago 😆. I’m sure I just did trial and error. You won’t fry anything.
I don’t remember covering the bottom but you don’t want anything to short, of course.
eldoj
9
05-05-2024 04:39 PM
calbear92
02-19-2006 10:28 AM
ABDCTTD
08-14-2004 05:53 AM
Neutron
05-28-2003 11:50 PM
808grouch
08-11-2002 07:45 PM
Quick Reply: You CAN replace the 'Door Open' micro-switch in the door latch.
