When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Audi TT 2.0L 2008 Engine Computer Control Module ECU 8J0907115T
Hi everyone,
While opening my ECU block with a screwdriver, I accidentally knocked off a few components. I managed to solder them back, but now I'm getting the error code P1602 - 002 - Voltage Too Low - Intermittent.
Can anyone help me find a photo of this ECU block, specifically in the area where the components were damaged? It looks like I might have soldered them back incorrectly.
You do not have the soldering skills needed to do that repair. It is highly likely that the board and components you've butchered are permanently damaged. Plus there is likely damage to the integrated circuit you chipped. That said, you may as well continue to hack away because you can't make it much worse.
