Audi TT Interior LED Lighting Package
#11
Audi should have given the US the footwell lights in the LED package, for crying outloud. And no lighting at all for the rear seats is a bit of a joke!
On another note, no adaptive feature on our xenon headlights either - why does Audi give their biggest market substandard lighting?
#12
#13
#15
I personally just had the same switch holder made this weekend for a single switch and ordered the switch per the forum. Then I ordered RGB 2 piece footwell LED light package from DeAutoKey: Complete Footwell Housing & Wiring Choose from a 4pc or 2pc kit fits: All VW/Audi models | deAutoKey
I live in Edmonton, AB, Canada, my 2011 TTS Convertible came with factory LED puddle lights, door handles and LED map lights. BUT it did not have factory footwells and trunk light was not led. I worked with DeAutoKey to order additional LED lights to make puddle brighter, replace trunk with new LED and also the footwells above. Also I ordered and installed reverse lights, LED red signals & white license plate lights. Only lights I did NOT change to LED were front fog and rear brake/tail lights. I like the factory fog for my use and DeAutoKey couldn't confirm if their tail/brake lights would through an error with my computer, so I didn't want to take a chance.
#16
In my 2013 TTS Roadster, I had only two very dim dome lights. And with a black interior, there are no wayward photons bouncing around.
I added this footwell light kit as well: Complete Footwell Housing & Wiring Choose from a 4pc or 2pc kit fits: All VW/Audi models deAutoKey which contains the standard light housings, original and LED bulbs, and a pre-built wiring kit. It was truly plug and play as a kit. When it's dark, I'm much happier with the amount of light in the cab as I enter the car. You can also have the footwell lights on during normal night time operation, at for instance 30%. But I turned mine off, as I don't need to see my dirty feet when I'm driving.
A VAG-COM bit change is needed to enable footwell lights on pin 50 of the "B" connector. I used my OBDEleven for that, which was easy. You end up with a menu item that controls the night time always on percentage. The default is 30% and I turned mine to 0%.
#17
#18
The VAG-COM bit was to turn on the footwell lights because the car came without them. I dimmed the footwell lights via the menu.
My footwell behavior now is to have full light whenever the dome light is normally lit, like when unlocking the car and opening the door. During normal operation the footwell lights are turned off because they are dimmed to 0% via the menu.
Using the remote would be news to me. They now work the way I want them. Time to forget about them and move on to more engine mods.
#19
w:http://deAutoKey.com
-Error Free LEDs for your Audi (interior & exterior)
f: https://www.facebook.com/deAutoKey
i: http://instagram.com/deAutoLED
AnimaTTor
TT (Mk2) Discussion
05-05-2007 06:55 AM
353/s/
TT (Mk2) Discussion
9
09-01-2006 10:38 PM
PGTT
17
01-27-2006 10:16 PM
TTigg
10-23-2002 09:27 PM
