Ceramic Brake Pads for 2010 Audi TTS?
#22
Thanks so much for the analysis and photos. I know that took a lot of time. It looks like the Hawk HB625.760 pads are a perfect fit.
I checked with EBC and while they have a pad (DP31946C) of the same dimensions, they state that it will not fit the 2010 TTS but they would have pads for the 2010 TTS by early 2011 (maybe).
So, I will be making the Hawk purchase soon. It is a shame that the sensor connector is not a direct fit with the OEM.
#24
I just did the fronts. For whatever reason, the fronts had exponentially more dust than the rears from the OEM composite pads. The rear rims do get dirty but it takes way more drive time. I estimate that the dust that developed in a few days of driving on the front rims takes several weeks on the rear rims.
I would really like to know the difference in 60 to 0 braking distance with the ceramics. I would guess it is probably a little worse compared to the composite pads. This is probably why (I think) I'm hitting the pedal a little harder with the ceramics.
All in all, I think that replacing the fronts only with the Hawk ceramics is a good compromise between asthetics and function.
#25
I believe the ceramics and the composite has different range of working temperature? The ceramics should be better at higher temperature than the composite. It should definitely be worst than composite when you step on the brake first thing in the morning. However, it should be better then composite when you do more aggressive driving..
#26
Congrats on the upgrade. I'd venture a wager that the normal fade after a number of high-speed pedal-stomps is probably non-existent for you!
#29
First I would like to thank TTS-AR for starting this. I have followed this from the begining and two months ago, I ordered both the front and rears for my late 09TTS from the Tirerack. I had 7500 miles at the time. Had my shop install with out any resurface to the disks. So: after 1000 miles I can say this is the 2nd best thing I have done ( the 1st was the chip ). Dust is 75% less, plus its is a dry dust and easy to clean. The old composit pad produced the oil/dust mixture and was a pain to clean ( even every two weeks ). No noise!!, braking pressure is about the same - and the car actually brakes better under hard conditions. Very pleased, so thanks again to all.
