Code 12425 2014 tt problems
![](https://cimg6.ibsrv.net/gimg/www.audiworld.com-vbulletin/1179x939/img_1315_a8beb835bea6fd4945fc34653976a475fef71d46.jpeg)
Hello!
I got my oil changed a month ago and when I got it back, the engine light was on. I took it back and they read the codes for me and it seems to be some sort of fuel pump issue. I’ve done some searching online and I really can’t find much about it.
It’s been driving fine until today when I got gas as I went to leave the gas station it just died. Several times I started it up went to hit the gas and it just died. I was an hour and a half from home and thank God it started up and ran and got me home -but now I know it needs to be fixed immediately
I’m hoping that I can fix it myself- but I just need to order the parts..and if I can’t fix it get it to mechanic quickly, because I need a car. (Single mom)
Has anyone had any experience at all? I live in the mountains and I’m nowhere near an Audi specific mechanic, so often times I need to do the research on what it needs… and go from there.
Appreciate any advice you can share!
From the Ross Tech Wiki - (link here)
19545/P3089/012425 - Signal Line for Fuel Pump Electronics: Electrical Malfunction
Possible Solutions
Since the issue can be one of two things, you need to figure out which one; (G6) or (J538), otherwise you may end up replacing a perfectly good part. If you don't get a good answer here, come over to the Audi TT Forum UK and post there also.
https://www.ttforum.co.uk/threads/20...9#post-9582699
Possible Solutions
• Check/Replace Transfer Fuel Pump (G6). See Special Notes
• Check/Replace Fuel Pump (FP) Control Module (J538).
Special Notes• Check/Replace Fuel Pump (FP) Control Module (J538).
• When found in the M.Y. 2006 - 2007 NAR BPY 2.0T FSI engine see:
• TSB 01-08-06 -or- TPI 2017131 which mentions "updated" electric/transfer (in tank) fuel pumps.
OlivineTTvert (05-18-2024)
pane2k
01-25-2007 05:18 PM
kookie
12-09-2004 01:21 PM
SteveJ_in_TX
10-17-2003 04:10 PM
Wowdi
04-11-2001 03:09 PM
