How fast did you get a build week assigned...
Re: How fast did you get a build week assigned...
353's correct. I never got a build week on the order I made with a dealer without an allocation. My build week was confirmed with in two days by the dealer with the allocation.
09 TTS Roadster/Q
Ibis
Prestige
09 TTS Roadster/Q
Ibis
Prestige
So if my dealer does not have an allocation...
...i will not know my build week? Would you guys switch dealer then or does it not matter? How can I find out if the dealer has an allocation?
Correct.
You car will sit in the "dealer" order bank until your dealer has allocation and then it will go into the "factory" order bank. Allocation is set based on several factors... others can answer this better than me, but I'm pretty sure is based off dealer volume and customer satisfaction. Also AofA will leverage models off each other... example... if they take low volume models they will get more higher volume models in return.
kreativecid
Q5/SQ5 MKI (8R) Discussion
13
09-25-2015 07:39 PM
