remote windows up and down coding
Hi, I would like to know if anyone has been able activate windows up and down feature by remote? I search vag com but can not find coding setting for 2008 Audi tt. I tried under coding 7 under 46 cent cov and all that said remote control were check but it does not work. Please tell what byte you changed, if anyone has made it work.
I did it, don't remember the code though.
It was just the adaptation code that showed up with a slightly helpful name in the VAG-COM software. Pretty sure it had "remote" or "windows" in the name.
long coding?
I thought the long coding was seperate from the adaptation channels. But then again, it's been a long time since I've used it. If I get a chance this weekend I'll try to find it, but it wasn't hard to just figure it out from the software. Just try the ones that look right until it works?
Here it is... (Using latest VAG-COM) 46 - Central Convenience, Long coding - 07, long coding helper
Find and uncheck "Comfort function power windows/sunroof via remote control inactive"
(the following was already set on mine, but check anyway)
Find and check the box for "Comfort opening power windows via remote control active"
Find and check the box for "Comfort closing power windows via remote control active"
click "Transfer Coding"
click "Do It!"
click "Do It!"
I don't think that will work. You'll need the intelligent HEX-USB+CAN or Micro-CAN from Ross-Tech
You'll need the new version of VAG-COM to do the long coding, and the newer versions only work with the intelligent adapters (no e-bay cables).<ul><li><a href="http://www.ross-tech.com/vag-com/cars/applications/ttr8.html">Interface Appliatrions</a></li></ul>
Cmmartin23
26
08-23-2016 04:44 PM
vwleadfoot
Audi Original "S" Cars
12-24-2015 06:07 AM
mdkv5
A6 (C7 Platform) Discussion
09-16-2015 01:09 AM
