Removing safty restriction to the sTronic gearbox
Hello, all!
I have a 2011 TT Coupe with the sTronic dual-cluth gearbox and I was wondering if there might be a solution for removing the safty feature that demands you to brake, before you pull the gear **** from Neutral to Drive position?
This is a very annoying feature on a car that is supposed to brake 62 mph in under 6 seconds because sometimes you loose 1-3 sec.only by trying to correctly engage to Drive....
Also, the brake pedal must be pushed rather hard in order for the D-Drive position to be engaged, as only a slight push on the brake won't suffice!
SkiingInABlueDream
A4 (B9 Platform) Discussion
05-08-2019 09:56 AM
