TT RS rear spoiler removal
Would anyone know exactly how to remove the rear spoiler from a TT RS? I am replacing the original spoiler with an oem carbon fiber spoiler. I will be using the OEM supports just replacing the spoiler piece. It looks pretty easy from just viewing but I don't want to mess the car up so was just curious if anyone had DIY on how it's done.
I just purchased a TTRS that has an OEM carbon fiber spoiler such as the one you're attempting to install.
If you look at the underside of the spoiler, you will see bolts (3 IIRC) in the middle section (between the 2 legs) that you will need to remove. In addition, on the same side of the spoiler but right outside of the legs, you will see two plastic covers that are covering a couple more bolts as well. You will need to carefully pry/remove these plastic covers/tabs, so you can get to the remaining screws.
The carbon fiber spoiler should bolt right up using the same holes/bolts.
Good luck, the car looks wicked with the carbon fiber spoiler!
Thanks, I knew about the bolts. I was more concerned about adhesive holding it to the support bar. If I know Audi they SUPER GLUED the crap out of it. I figured it might involve a little heat and some fishing line to remove and was trying to avoid that.
Thanks for your reply though and hope you enjoy your TT RS
Thanks for your reply though and hope you enjoy your TT RS ![Wink](https://www.audiworld.com/forums/images/smilies/wink.gif)
They haven't glued it on, it's fixed on with double sided foam sticky tape (like number plate tape) It takes two people to remove the top part of the spoiler, one to lift it up (quite firmly) while the other cuts the foam tape with a long knife. The carbon spoiler then fits straight on
BTCC A4
10-16-2000 02:47 PM
