will OZ Ultraleggeras 19" with 45mm offset fit TT?
Re: will OZ Ultraleggeras 19" with 45mm offset fit TT?
8,5×20" offset 45mm OZ Racing
Ultraleggera's with 235/30ZR20" tyres fit the TT 8J.
<img src="http://www.audiblog.nl/wp-content/tt-oz-5.jpg">
Jarod.
Jarod.
The greater the offset, the more the wheel will sit "away" from the car. The OEM 9 X 19 TT wheel with a 255/35 tire has a 52 mm offset. A 45 mm offset would move the tire 7 mm out - HOWEVER, the 8.5" wheel width is 12 mm (0.5 inch) narrower than the 9 inch OEM and therefore will move the tire 6 mm (one half of 0.5 inch = 0.25 inch) in - voila! - the wheel will fit within a 1 mm of stock if you run a 255/35 tire. Of course, there is some variation from tire to tire which could change the calculation a mm or two in either direction, but the bottom line is it should fit.
youngspeed
07-22-2006 03:19 PM
74carrera
12-06-2004 07:39 PM
Crazy Quattro
12-30-2003 10:13 PM
kutscha
Wheels & Tires Discussion
05-30-2002 05:15 PM
