When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
My MMI went dead while I was driving. First all the lights lit up....while turning into a gas station. After I stopped and restarted, it was normal. Then about 4 miles later, it started again and slowly shut down all the part of it till the screen was black....The car was running fine. I didn't know if I had brake lights because the blinkers didn't show up in the car at all so I pulled into a parking lot. After a little bit, everything came back but it had the check engine light and a caution triangle lit up. After restart, it only had the check engine light. I came on home about 4-5 miles and it was fine except the check engine light. I have a VagCom but no Windows computer to check it with. I have only 5370 miles on it.
