Sputtering on Warm Start - Leaky Injector?
#11
Hi,
My 2016 TTS MK3 seems to be having a similar problem. The problem occurs only intermittently and only when hot. The last time it occurred was about an hour after some spirited driving. It took a couple of attempts to start the vehicle.
My TTS does not throw any codes. It just seems to sputter when starting. Once it starts, everything is fine.
Do you know if your vehicle was throwing any codes?
I would get it looked at because I skipped timing in traffic and nearly blew my whole engine. The pump runs off of the camshafts which run off the timing chain so they are all related. As much as the work cost me, still cheaper than a new motor.
Hope this helps and doesn't scare you! But I think it's worth checking. Cheers,
REHA4GA (05-21-2024)
Byblos
9
07-25-2003 10:31 PM
