When Do TT RS Exhaust Flaps Open And Close On Sports Exhuast ?
#11
Not sure if any of you speak German and understood the explanation of what the module actually does in the video where he explains it. I noticed the subtitles don't work, but I speak German. There is some misconception here. The thing with the exhaust valves on any of the Audis is if you put the transmission in S, the valves open, but if you put the transmission back in D, they close. The valves always open at higher rpm to reduce back pressure. In the TT RS, it's somewhat more confusing because of the separate exhaust valve button. So, when you open the exhaust valves while in Park, but then put the transmission in D, they close. You have to open them again or put the transmission in S. I'm not so sure why this is all that confusing, though. Sort of a general rule is transmission in D => valves closed, transmission in S => valves open, unless you temporarily override it with the exhaust valve button. Regardless, the valves do open at higher rpm to reduce back pressure. It would be completely counterproductive for them to close at higher rpm.
What the module does is basically change the default behavior. If you press the exhaust valve button, the valves stay open, regardless of if you are going back and forth between D and S.
Also, the valves open on cold start, but then close. The module leaves them open after a cold start.
#12
I thought the valves open at cooks start-up, then close then open, they close just after 3500 revs then close and do not open until just after 5500 rpm.
As you say, that module, once initiated, keeps the valves open until the ignition is turned off.
#13
This will even get more confusing moving forward as the EU passed new noise regulations. The manual exhaust buttons will go away, and the valves will always stay closed below 80 kmh.
Despite it being a bit confusing, I can think of better ways to spend 500 Euro than this module. I think you'll learn how the factory programming behaves and you will get used to it.
Also, road noise etc. drowns out the exhaust on the TT RS, because due to being a turbo charged engine, the exhaust is not all that loud. So I think what you perceive as the valves closing is other noise drowning out the exhaust.
#15
Previously “CALE262”
$400 for a module that just keep the valves open, does it do anything else? I wonder how long it will be before OBDeleven has a fix for this, maybe a week or two, I think I’ll send them a message
https://obdeleven.com/en/
#17
#18
#19
I have developed a simple technique for keeping the exhaust valves open all the time. I keep the car in Drive Select Dynamic mode but select "D" for the transmission using the shifter and then press the exhaust button. To get the aggression from the transmission that I like, I use the paddle shifters or the stick shifter. This technique is particularly rewarding sonically when coming to a stop, downshifting when the revs get down to about 2000 and is most pronounced when downshifting into first. Couple of provisos are that the car must be warm and if you select "S" on the transmission, it will cancel the sport exhaust mode while in "D" so you will have to hit the button again. This technique is guaranteed to turn a few heads by delivering rewarding pops and burbles when coming up to stop lights and in particular with cars on both sides to reflect the sound. If you have not already figured it out, pulling down once on the stick shifter will cancel the transmission's manual ("M") mode when you use the paddles and put you back in to "D"
#20
Guys, I'm new to this forum and don't have a car yet, but isn't there a fuse that you could pull so that the muffler valves are always open? I know that the Corvettes and ZL1 Camaros have a fuse that controls the opening and closing of the muffler valves and pulling it allows the valve to stay open all the time.
