01314- No communications Intermittent
I am getting this code"
01314- Engine Control Module
49-10- No communications- Intermittent
Address 35
Controller
Note: Cant synch baud rate
I just switched from A box to M box for stage 3 and have not recoded the cluster yet. Could this cause me to not be able to communicate with engine.
I cant access 01- Engine but I can access Instruments all of the time.
I can also run auto scan- which takes until "trying address 08" to work, and once it goes to address 08 it scans everytime.
I also cleared the code and was able to acces 01 Engine flawlessly but once I turned the car off I have the same problem.
Any input, I checked the connections at the back of the OBD II port and it is secure. Anyone, thanks.
Address 35
Controller
What kind of interface are you using?
What version of VAG-COM?
-=Uwe-
-=Uwe-
http://www.Ross-Tech.com
Please answer the question.
What's written on it?
Where did you buy it?
Did it ever work?
-Uwe-
Did it ever work?
-Uwe-
--OOOO--Audifox
VAG-COM Discussion
03-25-2008 07:42 PM
SNogaro4
02-18-2008 01:28 PM
HKPassat
05-22-2004 07:23 AM
